Author Topic: Stupid Question Needs Smart Answer  (Read 3301 times)
NeoGenesisMax
« on: March 17, 2015, 01:32:03 PM »
I just did an oil change and replaced air and oil filters. What's up with the tube coming off the air box?  First time I drained it oil came out. The second time I drained it what looked like oil and smelled like gas came out.
Re: Stupid Question Needs Smart Answer
« Reply #1 on: March 17, 2015, 03:05:20 PM »
That's the crankcase breather overflow / filter. Extra oil/gas and white road grime stuff end up in the. Totally normal. Smells bad sometimes too.
NeoGenesisMax
« Reply #2 on: March 18, 2015, 04:53:58 AM »
Thank you. The two times I checked the tube it was full.  How often should I be checking it? Also I noticed the air box was oily behind the filter.  I did my best to wipe it up.
« Reply #3 on: March 18, 2015, 05:47:17 AM »
I usually drain every oil change, never that full really.
NeoGenesisMax
« Reply #4 on: March 23, 2015, 12:03:18 AM »
Is it normal for some of the air box to be saturated in oil and whatever else that could have been?
« Reply #5 on: March 23, 2015, 04:05:34 AM »
  if you have oil on the air filter, you are putting to much oil in the rear end gear box, sure makes a mess dont it,  I did it too,.
NeoGenesisMax
« Reply #6 on: March 28, 2015, 05:37:23 PM »
This was the first rear gear oil change. It came factory like that. I found the oil in the box before i did anything. I later drained the gear oil and filled ot until it stopped draining out the check plug.
« Reply #7 on: March 28, 2015, 07:41:44 PM »
  On my downtown 300i  the oil refill is .21 lt. ( 7.1 ) ounce, check the manual for your scooter, up to the fill hole is over full,   and thats go,s to the over flo,  to the air filter
NeoGenesisMax
« Reply #8 on: March 30, 2015, 05:14:07 AM »
My repair manual says to fill to the hole. So does my Kymco dealer.
0BARK4322
« Reply #9 on: May 17, 2015, 12:45:22 AM »
My manual say to fill to the hole also but i'm hearing that the manual is wrong and you should put only what is stamp on your gear box
ALL STOCK
« Reply #10 on: May 17, 2015, 02:25:37 PM »
So far, all Kymco models have a specific amount of oil for the transmission gearbox and filling to the fill hole is WAY too much. Regardless what any Kymco book or especially any dealer says.
« Reply #11 on: May 17, 2015, 03:42:27 PM »
Yep, I think you're safe to use what is indicated on your gear box -but some scooters do not have that marked there. Mine doesn't - so I use what is printed in the owner's manual.
I once asked KYMCO USA this question - "fill to edge of fill hole, or?"  They replied to fill as per the owner's manual....which often is not near the edge of he fill hole.
« Last Edit: May 17, 2015, 03:53:21 PM by Stig »
0BARK4322
« Reply #12 on: May 17, 2015, 03:50:08 PM »
The funny thing is that the owners manual say to do both......
ALL STOCK
« Reply #13 on: May 17, 2015, 03:55:34 PM »
They replied to fill as per the amount specified in the owner's manual....which often is not near the edge of he fill hole.
