Author Topic: How long does your air filter last?  (Read 985 times)
NeoGenesisMax
« on: March 17, 2015, 01:35:24 PM »
I changed out what I assume was the original air filter. In 7000 miles it was black. I work on cars and haven't seen a car air filter do that that fast. Hell I'm on 12000 miles on my car's air filter and it still looks new. What milage are y'all gettn' outta yers?
Re: How long does your air filter last?
« Reply #1 on: March 17, 2015, 03:08:35 PM »
Depends on riding conditions. Wet and or dusty less than 4000mi. Dry it'll last forever. Unlike your car the aixbox is inches from the ground and wheel, and it has about 1/10th the surface area of a car filter. One thing you can do if you get tired of buying $25 filters is cut out the paper filter from the plastic body and glue in K&N filter material, than just clean instead of replacing. It's about a $50 one time purchase.
NeoGenesisMax
« Reply #2 on: March 18, 2015, 04:55:48 AM »
Thanks for the input.
