Author Topic: Keihin PB16 Main Jet  (Read 1559 times)
demeter
« on: March 20, 2015, 02:05:47 PM »
So I just finished installing a bigger jet for my first time! Boy do I feel good.  ;D I'm a real man now right?  :P
Anyway I removed the airbox restriction while I was in there.
All the threads I viewed said the restricted jet was a 78 and to upgrade to 82 or larger. So I installed a 90. I bought a bag of sizes to play with it.
To my surprise the jet I removed wasn't a 78 but a 70..  :o Now I'm having second thoughts about installing a 90. I just put it all back together and haven't tried starting it yet.
2010 Like 50 2T (Malossi 70cc BBK, Tecnigas Next-R, Blue Polini Torque Spring, Yellow Clutch Springs, 5.5g Sliders, Stock Carb: 95 MJ, Stock Airbox Drilled, PIAA GT-X Headlight, Kolite 5630 Running Lights, 140/70-12 Rear Tire)
demeter
Re: Keihin PB16 Main Jet
« Reply #1 on: March 20, 2015, 05:23:19 PM »
Airbox restriction reinstalled.  :P
245luigi
  • Boston, MA
« Reply #2 on: March 20, 2015, 05:39:56 PM »
Wow thats a small jet! 90 MJ should have you running a bit rich. Check out the plug chop stuff to dial it in.
I found that the airbox restriction out while on the stock carb caused nothing but headaches
Currently:
2012 Kymco Like70
72cc Malossi BBK
Dell'Orto PHBG 19 AS Carb
52 Pilot Jet
92 Main Jet
W7 Needle, 40 Slide
2T atomizer + bushing
Tecnigas Triops
Malossi Torque Driver
