Author Topic: BBK install advice and questions.....  (Read 1253 times)
AgileWhitey
  • The captain sinks with the ship.....
« on: March 21, 2015, 03:09:58 AM »
So.. after waiting for the thaw its time to install my BBK. Was looking for tips and tricks anyone has! Also who has the best advice on break in procedure?
I'm hoping to hit a solid cruising speed of 45+! Exhaust, jetted carb and air filter are installed already. I have 7 gram weights and a 1500 torque spring to go in at that time.
Well you fellas are the best so let me know what you have!
BETTINandLOSING you are the man btw. Sorry for my ghost like attendance! Work and buying a house.....
The captain sinks with the ship..... (why am I the only one left swimming)
Re: BBK install advice and questions.....
« Reply #1 on: March 22, 2015, 06:02:09 PM »
BBk. not needed if you change rollers to 5.5 78 main jet and cut the cdi box. and a smooth drive boss. you should reach a good speed of 45 or better. If you do the bbk make sure you change the crank to.
AgileWhitey
« Reply #2 on: March 23, 2015, 02:33:30 AM »
Ive done all that and my best flat ground speed is 39-40 mph. I need those extra few mph to make my travels safer around my town.
« Reply #3 on: March 24, 2015, 12:06:18 AM »
have you tried to raise or lower the needle in the carb. and maybe a open air filter.
AgileWhitey
« Reply #4 on: March 25, 2015, 05:32:50 AM »
I have an open filter right now but i i do have it jetted a little high right now. In all truth I installed the bbk and I am taking it off tomorrow morning. Its a absolute nightmare! crazy vibration and my rings never seated and I have blow by like crazy! UGH.. You live and learn I suppose! All i want is a solid 45 mph!!
AgileWhitey
« Reply #5 on: March 27, 2015, 05:45:44 AM »
Put the stock 50 back in and now I have a crazy loss of power from where it was. I am sad to say I am pretty sure that I put the BBK head gasket back by accident. Is this a problem?? I thought maybe it would drop my comp ratio? IDK I need some help from the old guard here!!  :o
