Author Topic: ZX50 carburetor inlet fitting  (Read 4346 times)
yajblackburn
  • 2004 ZX50, 2000 People 50, 2002 Yup50
« on: November 09, 2009, 07:22:38 PM »
Hey guys.  I have a 2004 ZX50, recently the oil inlet fitting popped out from the carburetor.  I put the fitting back into the inlet where I thought the direction of the nipple would be facing (11:00 position).  After a few days I noticed a flat spot in acceleration.  I did the usual carb clean, spark plug replacement, fuel filter replacement and air filter cleaning and got no improvement.  I concluded that the oil inlet fitting must be at to much of a steep angle allowing excess oil to enter the carb causing the stumble.  I put the fitting nipple in the 9:00 position hoping it would fix the problem.  It somewhat did.  Under the service manual it shows the oil inlet located on the intake manifold, not the carburetor.  I dont know if this is where it was previously located prior to 2004, or after but I doubt someone ever changed the manifold and modded the carb to take the inlet line.  I was wondering if anyone has a picture or can tell me the position that their oil inlet fitting is positioned so I can rule it out.  Thanks .
Re: ZX50 carburetor inlet fitting
« Reply #1 on: November 09, 2009, 09:19:46 PM »
I,m not too good at all the drag&drop stuff, but I'll try to send the photo I have It shows the Oil line going into the INTAKE just above the reed cage. The line closer to the carb is the vacuum to the petcock. I just tried to copy /paste. Drag /drop. I don't get that stuff. Any way the Fact. set up is as stated. Even my Delorto set-up is the same. Is this a NEW scoot to you? I dont understand how it worked/ then NOT. Perhaps you got a stuck ring/ scored cyl. when the fitting came loose. I have both the zx/super fever manual, and the zx/ scout manual. They both show the oil line near the reed cage.
Shaka
« Reply #2 on: November 09, 2009, 09:22:43 PM »
Funny, they show it hooked to the manifold in the manual!  On mine the fitting is in about the 10 -11 o'clock position, it goes right over the top of the vent line just to left of it.  I somewhat doubt that the position is causing your trouble though.  I would think it more to be a possible vacuum leak around the fitting.  You may need to put something like Loctite 648 press-fit retaining compound on the fitting to make sure it is sealed in and won't pop back out.  My camera is charging, I can get a pic later if you need.
« Last Edit: November 09, 2009, 09:26:03 PM by Shaka »
yajblackburn
« Reply #3 on: November 09, 2009, 09:28:37 PM »
Thanks Zombie, the ZX is not new to me, Ive had it for over 4 years with 8,000 miles on it.  I also have a People 50 and the oil line is on the intake.  I think they made the ZX with the oil line going to the manifold for a few years then switched it to the carburetor....or vise versa.
yajblackburn
« Reply #4 on: November 09, 2009, 09:31:23 PM »
Yeah I should of have put some loctite or gasket sealer on the fitting when I put it back on.  Didnt think of that.  Thanks!
« Reply #5 on: November 09, 2009, 10:34:44 PM »
If you still have the flat spot I would check the cyl./pist.. The only carb mounted oil line I could find so far is the old school KEI-HIN used on early Honda 50's
Shaka
« Reply #6 on: November 09, 2009, 10:43:16 PM »
That's the carb, KEI-HIN!
« Last Edit: November 09, 2009, 11:07:10 PM by Shaka »
yajblackburn
« Reply #7 on: November 10, 2009, 12:58:05 AM »
Ahh thats a nice picture.  that should do, thanks!
Shaka
« Reply #8 on: November 10, 2009, 02:56:02 AM »
No Worries!  I just so happened to have one laying around! ;)
« Reply #9 on: November 10, 2009, 05:55:23 AM »
AMAZING shaka, Who on earth would have that carb. That's a three point shot if I EVER saw one!
