Author Topic: Oil Filter size?  (Read 1504 times)
jayocampo88
Oil Filter size?
« on: March 29, 2015, 06:16:04 AM »
Hey again, I know, I might be getting some of you mad  >:( >:( >:( >:( >:( >:(
And I'm honestly sorry!  :-[ :-[ :-[ :-[ :-[ :-[ :-[ :-[
But, I'd rather make stupid questions than stupid mistakes. So with that in mind...
What is the Oil Filter size or part number???
Thanks in advance guys!
Re: Oil Filter size?
« Reply #1 on: March 29, 2015, 07:20:29 AM »
You're in luck, there is no oil filter!!!
Rudolf
  • Born to be wild!!!
    • Facebook
« Reply #2 on: March 29, 2015, 08:11:01 AM »
There is a small strainer the size of a larger thimble, that sits inside the oil drain plug along with a spring underneath the engine.
The code for the oil filter strainer is: 15421-107-0000 and the spring for the oil filter strainer 15426-GE1-9200
« Last Edit: March 29, 2015, 08:15:14 AM by Rudolf »
MaryK
« Reply #3 on: March 29, 2015, 11:26:53 PM »
You don't need to replace anything except the oil.  1 qt as I remember.
With no filter, I would change oil every 1000 miles.
scoot safely,
New Rider in 2010
2009 GrandVista 250
jayocampo88
« Reply #4 on: March 30, 2015, 03:00:26 PM »
Sweetness!!!!
on that note. How difficult is it to change the drive belt and spark plug??
Imma DIY kind of guy you know?
« Reply #5 on: March 30, 2015, 08:55:13 PM »
Sweetness!!!!
If you're going to be fiddling with your scooter a lot - (Like me) - you might want to look into buying a manual (on-line, or paper) from www.cyclepedia.com
I bought the life-time subscription, and have used it repeatedly with good results.
Pretty sure they list your scoot.
The shop/labor prices of my dealer encouraged me to do a lot of stuff myself. Got all my tools and the manual for about 1 hour labor time.
Typical picture from the web site of my manual....
