Author Topic: Tube inside air box  (Read 1663 times)
gosku
  • Start me up!
Tube inside air box
« on: March 31, 2015, 04:28:57 PM »
Hi!  :)
Many times I've been wondering what's the purpose of this tube inside air box. I thought that it prevents water and dirt from entering the air box, but if that's the main reason then it is doing its job quite poor - after rain when I open the air box there is always some water and dirt inside. Then I thought that maybe this tube is some kind of restriction? Like it prevents more air from entering the air box, reducing power and so on. It's made from rubber and getting rid of it should be quite simple. Any ideas is it worth doing so?
Kymco People S 50 2T 2008
Tecnigas Next-R Pipe
Malossi torsion controller 2512828
Malossi rollers 7g
Michelin City Grip front + Heidenau K66 rear
Re: Tube inside air box
« Reply #1 on: March 31, 2015, 07:16:38 PM »
Hi!  :)
You can gain a mph or two by taking it out, but you will have to play around with the jetting and mixture. On a100% stock engine it's almost not worth messing with it.
gosku
  • Start me up!
« Reply #2 on: April 10, 2015, 08:28:24 AM »
Thanks  8) I'm leaving it as it is (at least for now :P)
Malossi rollers 7g
mclark999
« Reply #3 on: June 13, 2016, 05:48:36 PM »
I took mine out after putting on a performance exhaust. It lets in a lot more air. I had to rejet for the exhaust so just did the jetting to work with the larger opening.
Sent from my SM-G900V using Tapatalk
2007 Kymco People 50 2T
Tecnigas Trek exhaust
OEM 16mm carburetor
MJR
« Reply #4 on: June 13, 2016, 05:57:39 PM »
I'd say more than likely it's in there for air flow tuning and noise (resonance and airflow). I don't think most people realize how loud an unturned intake can be much like exhaust.
« Last Edit: June 13, 2016, 06:00:05 PM by MJR »
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
