Author Topic: Strange clock problems  (Read 931 times)
hypophthalmus
« on: April 01, 2015, 02:33:08 AM »
My clock has been behaving strangely for some time. Once in a while it'll work fine. Sometimes it'll be very dim. Often it'll be flashing different parts of the numbers, at different rates. Sometimes completely blank.
Thoughts?
Re: Strange clock problems
« Reply #1 on: April 01, 2015, 04:11:27 AM »
Most likely the battery. The clock has its own small lr43 watch battery. If it's not that, the whole clock is only like $30 to replace.
hypophthalmus
« Reply #2 on: April 11, 2015, 10:58:49 PM »
Thanks, replacing the battery worked. I went with an SR43SW battery. Same size, but it might last a bit longer.
While I suppose it wouldn't have been a huge deal in the long run, I'm glad to not have had to pay $30 for a new clock, especially after having seen it taken out.
