Author Topic: Tire pressure on downtown 300i  (Read 6446 times)
Going Downtown
« on: April 04, 2015, 07:06:56 AM »
Anyone tell me what the tire pressure should be on the downtown 300 i with manufacture tires? Thanks
windwheeler
    • WindStrom windshields
Re: Tire pressure on downtown 300i
« Reply #1 on: April 04, 2015, 10:36:14 AM »
If you wish to go "by the book" look what the owners manual states, or the sticker on your DownTown.
If you want to go with "my experience" based on many, many miles on many different motorcycles and scooters: As high as yo can "stand" and is permitted by the TIRE manufacturer, printed as "maximum load pressure" on your tire's side-wall.  However, if it says e.g. 44psi or even 50psi, my "cut-off" top pressure is 40psi, and I check often so it never falls below 36 psi.
This conclusion for me is based on "safety", "not wanting to bend rims" on potholes, and "tire life".
That works for me very well, doing a lot of curvy roads.  If one rides mainly straight and no-pothole roads, a lower air pressure between 34-36psi works well too.  However, my experience showed over the years, in general, higher air pressure (for street use, not racing) has technical advantages and is safer.
« Reply #2 on: April 04, 2015, 10:42:59 AM »
   the book says  2 kg.  front and 2.25 rear,  ( 28 lb. and 34 lb. ) you ride it and adjust to your own liking, about 1 lb up or down
Going Downtown
« Reply #3 on: April 05, 2015, 01:28:06 AM »
Thank you.
« Reply #4 on: May 07, 2015, 10:08:15 PM »
Going over recommended PSI will lower tire/road contact area - but probably not enough for non-racers to notice.
Ironically - One size larger (wider) tire has the same loss of area effect....but, again, most won't notice.
This was explained to me buy a pretty smart veteran bike rider/parts manager.
He showed me with a tire.
kneeslider
« Reply #5 on: May 08, 2015, 01:03:59 AM »
28 psi sounds a bit on the low side, but i guess perhaps the scooter has most of its weight on the rear.
2019 Yamaha X-Max 250
RubenC
« Reply #6 on: May 08, 2015, 03:06:16 AM »
The 2012 USA Owner's Manual says front 29Lbs and back 32lbs.
From the Great Nation called Texas. Oops I mean the Great State called Texas
nushipwright
« Reply #7 on: May 08, 2015, 06:07:00 AM »
I inflate mine to just over the manual recommended.  2 for front and 2.25 rear, and just a tad over those values when cold.
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.”  - Mark Twain
. mostly 2up city
