Author Topic: carb jetting with tecnigas pipe and Uni pod airfilter  (Read 6862 times)
Re: carb jetting with tecnigas pipe and Uni pod airfilter
« Reply #30 on: June 05, 2015, 10:59:45 PM »
WhT would be nice is a temp gauge that screws into the spot for the original overheat temp sensor, that would be nice
Possibly could just use that sensor, IDK.
Scootsuper9
« Reply #31 on: June 11, 2015, 11:18:40 AM »
Bought mysf a 2t atomizer and bushing from dellorto direct. They're owned by 1977 mopeds who I've delt wth but the order has been processing since Saturday so idk. That is supposed to fix my pig rich 1/4 throttle issue which is always nice. Will give an update when/if my goodies come in
Triesandluth
« Reply #32 on: June 11, 2015, 10:22:29 PM »
I always forget about that.  When you  get it would you mind posting some comparison pictures?
