Another suggestion would be to change the variator rollers to lighter ones. It will give you a little better acceleration if you ever need it. I would also suggest using full synthetic lubricants in your motor and gear case and a iridium spark plug.
Thanks for the reply and good suggestions.
I replaced everything with full synthetic(10w40 Castrol Motor Oil and 75w90 Motul Gear Oil, both full synthetic). I checked the spark plug in it, and looks like it still has a bit of life left on it since it was fairly clean and good condition.
Would you please provide me with some more info(a link perhaps) about variator rollers so I can look into that. Would love to get a bit more acceleration if I can. I'm also going to purchase a new CVT belt as soon as I get a chance because I don't necessarily know the condition of the current, especially if it's just been sitting around and not being used.
Also, any suggestions on muggy throttle cables? Mine seems to be a little spotty at times and I don't know if I should look into just lubricating it or replacing it. I have already adjusted the idle to a good setting, and plan to play with the air/fuel when I have some time.
You can do some led mods.
Life replacing bulbs with LED's? Any suggestions?
Wear neon clothing jacket, bright fullface helmet.
I own a 3/4 helmet, and don't know if I should invest into a full face. I've heard some bad stories, so I am considering it, but I do only commute about 7-9miles to work at a maximum of 35-40mph.
Mechanically sounds like you've done well. You can remove CVT cover and take a peek inside and measure the belt width to see if it need replacing and to see if its real dusty and needs wiping out with a rag.
Thanks, I am the son of a long time mechanic, so I know my way around may things! I'll take a look at that belt!
When were the sliders/rollers last replaced ?
No idea..... doubt they were every touched. When I purchased the bike, it was clean on the exterior, but internally, you can tell it had accumulated a bit of garage dust.
Maybe an ounce of seafoam every 5-10 tanks of gas.
I've only pour a little bit into the past 4 tanks, since the bike had sat for a long time and I'm not sure on how much build up was in it.
Thanks again!
