Author Topic: Top box gasket alternative  (Read 988 times)
TroutBum
  • 2012 Like 200i (sold)
« on: April 12, 2015, 04:28:04 AM »
Today while riding I heard a load chattering from the top box. I pulled over and opened the lid to discover nearly a third of the gasket was gone and the remaining was at various stages of disintegration. Looking through the Kymco parts there doesn't appear to be a replacement gasket without buying the entire box unit. Any ideas on what I can use as an alternative? I went to Michaels thinking I would found find something like those rubber stringy things used for making beaded jewelry, but all I could find was the hard plastic type. I need something that is a bit spongy to absorb the vibration of riding.
« Last Edit: April 12, 2015, 06:48:22 AM by TroutBum »
Re: Top box gasket alternative
« Reply #1 on: April 12, 2015, 04:46:22 AM »
Get some one sided sticky foam tape from home Depot, or they might have rubber. Anyway there will be something there that fixes it!!
TLRam1
« Reply #2 on: April 12, 2015, 05:23:48 AM »
I use weather stripping between the top and bottom halves.
Terry
10 Kymco People S 250
87 Yamaha Riva 200 (Sold)
Allen TX (Dallas)
cli-maxridinggear.com
bluesin
  • 2012 DT 300i
« Reply #3 on: April 12, 2015, 01:23:58 PM »
My gasket is more like spline for a screen .
2wheelfun
« Reply #4 on: April 12, 2015, 05:26:27 PM »
Put some blue rtv silicone in the groove, let it dry and your good to go. About half way deep all around.
TroutBum
« Reply #5 on: April 13, 2015, 04:57:00 PM »
Thanks folks. I ended up using a seal from an old gun case I had. I had to trim it as it was too long, but a little Crazy Glue fixed that. Now I ride chatter free once again.  8)
