I have been having recurring problems with my Agility 50 dyeing after about 45min of riding and often at WOT. I have recently cleaned with carb cleaner and saw light through the jet's pin holes. One of the last times it killed on me while riding, I coasted to the streetside and pulled the plug. As you can see, I have a lean condition.
I adjusted the air/fuel mix with a digital tach and it was optimized at almost 4 turns out which is quite a bit above the 2.5 recommended in the service manual. The mix screw turned that far out while still running lean means I need a larger main jet, right?
After all the hassle, I'm thinking of taking the easy way out and ordering one of the below-linked carbs. I've read so many horror stories on this forum of people ordering jets that don't fit the threads/jets that take forever to come/bad customer service.
That said, does anyone think one of the two following links are the easy answer to my problem? I've read here that 20mm carbs are plug and play, but even for GY6, there seem to be many variations.
Or do you recommend some other quick solution or link to a carb you recommend? I really need to use the scooter right away. Thanks in advance for any help!
This one says it's for big bore scooters, but maybe it would work for a stock scoot as well?
http://www.ebay.com/itm/True-20mm-Performance-Carburetor-139QMB-GY6-Scooter-Carb-KEIHIN-CVK-50cc-100cc-/171734637047?hash=item27fc2e99f7&vxp=mtrThe description for this one specifically states it's for a Kymco Agility, but doesn't list jet sizes:
http://www.monsterscooterparts.com/kymco-agility-50-19-mm-carburetor-with-electric-choke.html
