Author Topic: valve stem replacement/extension.  (Read 1582 times)
rick71
« on: April 13, 2015, 01:56:06 PM »
I apologize if this has already been hashed over.
Does anyone have a suggestion replacing the stock valve stems or an extension? It is nearly impossible for me to get an inflation valve on the stock valve stems.
Any and all info appreciated.
Rick
sissy mary
Re: valve stem replacement/extension.
« Reply #1 on: April 13, 2015, 02:45:26 PM »
I bought an extension that is used for trucks with dual or what is called dually wheels. This, about 1 foot long extension screws on to the stem, and it gives you plenty of length to easily ad air to the tire. Found them at pep boys. A normal car extension really does not work well on/for the X500.  :-*
rick71
« Reply #2 on: April 16, 2015, 01:29:44 PM »
Thanks, Sissy Mary. We don't have Pep Boys here, but I'll take a loot in the auto stores.
For others...
Has anyone installed 90 degree metal valve stems?
Might the wheels have to be balanced to use them?
Rick
bongoman
« Reply #3 on: April 16, 2015, 05:15:38 PM »
I was told by a shop tech that the 90 degree valve stems is a bad idea because of wheel rotation at high speeds, break it off and you have a flat.
I use a short pressure gauge that works ok.
2009 Xciting 500
2015 Lance Cali Classic 150
rick71
« Reply #4 on: April 16, 2015, 08:40:11 PM »
I am not sure how they would break off. I don't think they would protrude past the discs.
Rick
« Reply #5 on: April 16, 2015, 08:57:12 PM »
90 degree valve stems should work just fine, they come in bikes from the factory. I don't think the wheel produces enough centrifugal force to break the valve stem off, even going 100mph
rick71
« Reply #6 on: August 31, 2015, 05:27:21 AM »
I got the extension, but getting it onto the front valve is still hard. I think a local parts store has screw on 90 degre extensions. I'm going to try using that with the 1 foot extension. Hopefully I can just connect the one foot extension to the 90 degree and use that when needed, but not leave it permanently installed.
With increasing problem with my knee and my growing belly, keeping the tires inflated is discouraging me from ridging. Hopefully this will will fix it. :-)
Rick
« Reply #7 on: August 31, 2015, 06:17:07 AM »
  I took the wheel off and let the air out sqweezed the tire and put a new 90 degree stem in, works perfect Im 82 years old and it was easy,
