Author Topic: stuck gas gauge  (Read 1253 times)
mnpugdog
stuck gas gauge
« on: April 13, 2015, 11:39:55 PM »
So sitting over the winter caused my gas gauge to stick in the full postion, anyone know how to unstick it?
Re: stuck gas gauge
« Reply #1 on: April 15, 2015, 12:40:26 AM »
  Bounce the front of the scooter  up & down,. that should move the fuel gauge,
jeffreyholt79
Re: stuck gas gauge
« Reply #2 on: April 15, 2015, 03:27:14 PM »
Take out the float and hit it with carb cleaner..i had to do mine the other day on my GV 250
Re: stuck gas gauge
« Reply #3 on: April 15, 2015, 05:05:22 PM »
Another thing you could try before removing the sending unit, take a metal clothes hanger and straighten a section out and make a large J shape and try to reach it in the tank and pull / push the float up and down a few times to break the corrosion loose. If this doesn't work you can take it out and clean the contacts.
mnpugdog
Re: stuck gas gauge
« Reply #4 on: April 15, 2015, 11:06:44 PM »
thanks guys I will try all and see which helps
