Author Topic: Strangely Dead People 50  (Read 1644 times)
rwsykora
« on: April 14, 2015, 01:22:22 PM »
My 2003 People 50 worked flawlessly last fall. When snow came, I pulled the battery and kept in in the shop for the winter. I re-installed it this spring and ... no starter, no clock, no horn, no lights. Yes, the battery polarity is correct. There's zero battery connection corrosion. But it's as if the battery isn't there. The voltmeter shows it with a 12.8v charge. AND -- get this -- when I touch the battery's + terminal with the red probe of the voltmeter and put the black probe on a chassis bolt by the rear wheel ... it shows 12.8v on the meter! Anyone with electrical smarts have an idea?
Chris0381
Re: Strangely Dead People 50
« Reply #1 on: April 14, 2015, 01:57:24 PM »
When the batteries are fully charged, they read about 12.8 volts with the charger on mine. After a long ride it reads 13.2 volts.
Are all your fuses OK and no corrosion? Are your wire harnesses all connected nicely with all bullet connectors well seated ?
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
rwsykora
« Reply #2 on: April 14, 2015, 02:40:24 PM »
Fuses test OK! All connections as clean as can be. I suppose a mouse could've chewed wiring inside that I can't see, but I don't think there's anyplace for a mouse to get in.
wkreps
« Reply #3 on: April 14, 2015, 02:45:40 PM »
Will it kick start?
Wayne
rwsykora
« Reply #4 on: April 14, 2015, 03:00:49 PM »
Tried kick start, no luck. But that might not help the analysis, since it usually is pretty difficult to start with a kick.
« Reply #5 on: April 14, 2015, 03:27:35 PM »
If the battery sat during the winter without being on a maintainer it's dead. Static battery voltage doesn't tell you much. Put the volt meter on and check the voltage with the key on, most likely it'll drop too near zero. These scooter batteries do not like to sit around. Also your bike will need a carb clean to run right, along with fresh gas.
« Reply #6 on: April 14, 2015, 07:52:39 PM »
Battery or ignition switch.
rwsykora
« Reply #7 on: April 16, 2015, 05:26:57 PM »
Yup: with ignition on, voltage dropped form 12.8 to 0.05. New battery; all is good. Thanks for the excellent advice, I no longer see Dead People!
« Reply #8 on: April 16, 2015, 07:04:38 PM »
 :D 8) :P
