Author Topic: TPS code  (Read 1492 times)
solberglandandcattle
TPS code
« on: April 14, 2015, 10:04:01 PM »
I've started to narrow my no power problem down its running a TPS code, now I ordered a new sensor and put it in, and it's still running the code, anybody have any ideas??
Re: TPS code
« Reply #1 on: April 14, 2015, 10:13:24 PM »
what kind of scooter do you have , to have tire sensor code read out,. is that part of ABS brakes,
Re: TPS code
« Reply #2 on: April 15, 2015, 07:33:54 PM »
It's a 2012 500i side by side. I was meanin the throttle position sensor
Re: TPS code
« Reply #3 on: April 15, 2015, 09:43:30 PM »
Could be the ECU itself not picking up the TPS signal. Double check all the wiring too.
carmen007
Re: TPS code
« Reply #4 on: April 20, 2015, 06:30:51 PM »
Are you getting a 06 code
2013 Kymco People GT 300I
14g Dr pulley
2009 Schwinn Newport 150
2012 Genuine Buddy 125
Re: TPS code
« Reply #5 on: April 22, 2015, 07:56:57 PM »
It's giving me a p1121 code, put a new throttle position sensor in and no change, can't get rid of the code nothin
JoeMarshall
Re: TPS code
« Reply #6 on: June 01, 2015, 01:11:58 AM »
Did you get the code to disappear. and did you do the reset procedure. Also you will need to do the relearn for the tps.
