I had the aim originally set for the regular bulb, which was okay. I did some on the fly adjustments that did no good. If it's not rainy tonight I may try to set it up better. I think the bluish hue was throwing me off with the wet streets, wet windscreen, and wet face shield.
Honestly, the load seemed to not change too much, just no drop in brightness at idle. But with the original bulb pulling 35w, this is possibly pulling half. Everything still gets hit by the signals. I'm hoping the led signal bulbs that are on the way will relieve the issue with the intermittent dimming while the indicator is on.
My model only has one setting for the headlight. On. Ha ha. I was confused about that when I got it, since my cheap Chinese scoots have high and low settings. This has no switch at all. I've seen somewhere a way to wire it up, but I'm okay with it as is. I'm not sure on the bulb set up if it had that option.
Anyways, the next bulb is on its way, it doesn't even have to come from far, so it should be in soon.
