Author Topic: Brake fluid  (Read 1196 times)
MrXT
Brake fluid
« on: April 19, 2015, 07:46:10 PM »
Manual recomends dot4 but it doesn't say synthetic or non synthetic so what's in it from stock??? Am I forced to bleed the brakes before topping it up the first time??
Kymco agility city 125cc (2013)
4000km
Re: Brake fluid
« Reply #1 on: April 19, 2015, 10:21:49 PM »
I'm pretty sure they just use DOT4 regular brake fluid from factory. You can use synthetic, but you have to bleed the entire system free of the regular stuff to use synthetic. If you use regular DOT4 you can just top off and go.
MrXT
Re: Brake fluid
« Reply #2 on: April 20, 2015, 03:30:28 AM »
So non synthetic is what comes with it from stock??
4000km
donatello
Re: Brake fluid
« Reply #3 on: April 20, 2015, 06:25:55 PM »
yes, stock brake fluid is non-synthetic MrXT
