Author Topic: Agility 50 charging system PLEASE HELP!!!  (Read 754 times)
phil c
« on: April 22, 2015, 05:57:00 PM »
Hi guys n gals. Please help if you can.
I have a problem with the charging system on my agility 50.
Battery volts full charge is 12.7,  Cranking charge is 10.8 volts.
When I rev the engine the voltage from the generator goes up to around 13.5, then when revs  go over 50% throttle, it drops to around 5 volts. Is this normal?
Trying to work out why it wont turn over in the mornings enough to start it. I have tried with lights off, and even tried kicking it over with the s/motor, but some days it just wont go. Then next day, it fires up first push of the button.
Any suggestions please!
Re: Agility 50 charging system PLEASE HELP!!!
« Reply #1 on: April 22, 2015, 06:12:43 PM »
Sounds like a bad regulator. Cheap and easy.
« Reply #2 on: April 22, 2015, 11:31:00 PM »
when did you reset the valves last.
phil c
« Reply #3 on: April 23, 2015, 11:11:05 AM »
Valves have been checked all ok. When its going its fine runs perfectly. Just the starting problem. I reckoned it was either the genny or the relay. Thanks for the advice on the relay, I'll fit a new one and see.
« Reply #4 on: April 25, 2015, 02:09:22 AM »
How old is the battery.
