Author Topic: Improving top speed and high end RPM  (Read 7028 times)
leo.portner
« on: April 24, 2015, 04:28:47 PM »
On my 250i when going 110-115 km/h
The engine rpm is 7500 just befor the red line.
Hod do i reduce the rpms at this speed?
Rollers slidera moltivar??
What is the best way
Re: Improving top speed and high end RPM
« Reply #1 on: April 24, 2015, 04:55:00 PM »
Heavier sliders will improve top speed RPM. But when the variator is maxed out (Around 80mph on my 250) there is nothing you can do to reduce the rpm, because the bike is in it's final gear ratio. The variator is as big as you can go, only a few MM away from the engine case. A slightly larger diameter rear tire will help a little, double check if there is enough room to squeeze that in there. Otherwise, I ride my 250 at 7500-8000 rpm all day long with no problems what so ever. Hope this helps.
leo.portner
« Reply #2 on: April 24, 2015, 06:11:07 PM »
I drive 50 miles every day
At 70 mph the rpm is on 7500
I want to stay going on 70.mph but reduce the rpm will hevier rolers or hevier sliders help? What is the main difference.bitween the 2
« Reply #3 on: April 24, 2015, 06:21:43 PM »
They might help a bit, sliders open the variator a little wider allowing higher top speed. Heavier will be lower RPM at any given point UNTIL the variator hits its maximum gear ratio.
leo.portner
« Reply #4 on: April 24, 2015, 06:57:55 PM »
What size sliders do i need and what weight is recomended
« Reply #5 on: April 24, 2015, 07:07:50 PM »
23x18 Dr. Pulley sliders. Weight is a personal preference, you should be around 20-24g depending on what you like the feel of. I have 18g on my B&W but I like to to rev up for more power. Keep in mind if you do heavier weights, it will accelerate SLOWER and be slower up hill.
leo.portner
« Reply #6 on: April 24, 2015, 07:13:11 PM »
leo.portner
« Reply #7 on: April 24, 2015, 07:14:04 PM »
Is this what i need
« Reply #8 on: April 24, 2015, 07:40:56 PM »
Those are correct, although that shipping price is INSANE. What country are you in? Call these guys:
Buggy parts NW https://www.buggypartsnw.com/
leo.portner
« Reply #9 on: April 24, 2015, 08:15:12 PM »
Allredy had this conversation man... Im from israrl
« Reply #10 on: April 24, 2015, 08:18:40 PM »
Sorry about that!!! Forgot it was the same 250AFI!!! Those weights are correct, just make sure they are the correct weight you desire.
leo.portner
« Reply #11 on: April 24, 2015, 08:25:03 PM »
25 or 28 g
Im thinking
My drive is a long high speed no hills if i can get the 250 wotking in less rpms
« Reply #12 on: April 24, 2015, 11:06:02 PM »
25 or 28 g
Im thinking
I would try 25, 28 will be very very heavy for that engine. If you are good with tools, you can get the 28g and then if they don't work use a dremel tool and shave off some of the brass to lighten the weights. Don't you need that acceleration to run from rocket strikes though?
leo.portner
« Reply #13 on: April 25, 2015, 08:04:00 AM »
Lol!!! Good one!
Your right i will go 5g
« Reply #14 on: April 29, 2015, 03:24:16 AM »
  Take your variator cover off and see how high the belt goes on the vaiator, rev the moter up and take a look,  just make sure the bike is stable on its center stand,
