Author Topic: Light problems  (Read 553 times)
ANDYG828
Light problems
« on: April 25, 2015, 07:56:16 PM »
Hi, can anyone help me? I have a 2010 Kymco Agility 50 and I took it for an M.O.T today and it failed due to the centre front headlamp not being able to illuminate on the dipped beam. They weren't able to tell what it was while it was their for the hour so can anyone help me or give me an educated guess as to what it could be? Thank you
Re: Light problems
« Reply #1 on: April 25, 2015, 08:13:29 PM »
So you're headlight bulb is out? Most likely just replace the bulb...
0BARK4322
Re: Light problems
« Reply #2 on: April 25, 2015, 08:19:05 PM »
Get a new headlamp bulb :D.....................welcome
ALL STOCK
ANDYG828
Re: Light problems
« Reply #3 on: April 30, 2015, 02:58:11 PM »
I have replaced all 3 bulbs and that still hasn't done anything when I turn the bike onto the normal headlight beam. It has a high beam and sidelights and indacators but no normal beam.
Re: Light problems
« Reply #4 on: April 30, 2015, 03:07:59 PM »
Clean the lo/hi switch with electrical contact cleaner.
