Author Topic: How to remove carburettor  (Read 760 times)
T33omm
« on: April 26, 2015, 06:35:11 PM »
Hy guys can someone shred some light on the easiest way to remove carb just seams so tight to get to anything it's a 2014 super 8 50cc 2t just need to change main jet
Chris0381
Re: How to remove carburettor
« Reply #1 on: April 26, 2015, 09:33:31 PM »
This helped me
Look at the schematic first to familiarize yourself with the parts.
Dont forget to drain bowl via drain screw and hose that hangs down.
Dont lose the pin holding float bowl to needle.
Dont over tighten on install.
Handle gaskets with care.
Slide is a little tricky putting back in but once lined up properly, it goes down easy where you then screw on the throttle cap.
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
T33omm
« Reply #2 on: April 27, 2015, 06:00:08 PM »
Thanks for the info and the link been hrs looking for a vid with our metal inlet just waiting on a new nut for my clutch cause it rounded and the bike is done
This helped me
Chris0381
« Reply #3 on: April 27, 2015, 06:17:00 PM »
You are welcome T33. Hope all goes well for you. I bought a spare 39mm clutch nut myself just in case.
Smooth Boss
Polini Variator
#95 Main Jet
