Author Topic: Super 8 loose hose or tube?  (Read 847 times)
19basketball89
« on: April 28, 2015, 10:17:03 PM »
Noticed this loose/disconnected hose/tube while doing an oil change. Doesn't appear to leak anything. Anyone know what it is?
Re: Super 8 loose hose or tube?
« Reply #1 on: April 28, 2015, 10:37:16 PM »
That's your drain hose for the carb float bowl. It should never drip anything unless you open the float bowl drain screw.
19basketball89
« Reply #2 on: April 29, 2015, 10:40:47 PM »
So, it is fine where it is?
« Reply #3 on: April 29, 2015, 11:11:16 PM »
It's where it belongs!!! If you don't like the look, you can yank it off.
