Author Topic: need help asap  (Read 666 times)
ritaspug
need help asap
« on: May 03, 2015, 05:50:54 PM »
I am doing my own tune up on my 2010 like200i, i was distracted while putting new transmission fluid in and now it is over filled. do I just keep letting it drain out of the fill hole or go ahead and take the drain nut back off and start over? worried about fowling up the rest of the engine, air filter if i close ot up and start it right now. :-\
rita
Re: need help asap
« Reply #1 on: May 03, 2015, 05:58:05 PM »
Drain it. Kymco is not like other bikes where you fill tell it weeps. You need exactly 180cc or it will leak into your airborne and make a mess of things.
ritaspug
Re: need help asap
« Reply #2 on: May 03, 2015, 06:08:01 PM »
thanks, gonna do it immediately.  :)
rita
Re: need help asap
« Reply #3 on: May 03, 2015, 06:13:09 PM »
