Author Topic: Stig's patented "Visor Buddie"  (Read 5881 times)
« on: May 03, 2015, 10:34:33 PM »
Invented this myself.
Always carry a roll under my seat now for those low-sun times on the scoot.
Hey it works and it is better than riding around one handed.
« Last Edit: May 04, 2015, 12:21:06 AM by Stig »
0BARK4322
Re: Stig's patented "Visor Buddie"
« Reply #1 on: May 03, 2015, 10:38:51 PM »
WOW! I'll take ten of those,  do the paint come with it ???
« Last Edit: May 03, 2015, 11:17:39 PM by 0BARK4322 »
ALL STOCK
2wheelfun
« Reply #2 on: May 03, 2015, 11:11:49 PM »
OH OH Stiggy has honda-itis, he forgets Kymco rules here bouts, capiche pilgrim?
manimal
  • 2013 Super 8 150
« Reply #3 on: May 04, 2015, 03:59:12 PM »
lulz
I have something similar on a few of my visors. I have a strip of the pealable / removable window tint. You can get this stuff at any local auto store, or online. I currently use the "medium" tint, and works well for my evening commute. My morning commute is either dark, or away from the morning sun. I do recommend the darker tint for those that have a long commute w/ direct sunlight.
~Daren
California (Nor*Cal)
bluesin
  • 2012 DT 300i
« Reply #4 on: May 04, 2015, 05:07:57 PM »
My HJC has a sunvisor ( inside the regular visor) that I can just push a button to put it down or raise it up .
 8)
AMAC1680
    • SEGS4VETS
« Reply #5 on: May 04, 2015, 05:42:35 PM »
Simple but effective. Love it.
Be Big,
AMAC
www.SEGS4VETS.org
2017 Lance Cali Classic 200i
2013 SYM RV200
2013 Kymco Downtown 300
2010 Lance Cali Classic-sold
1973 VW Dune Buggy
1974 VW Meyers Manx
« Reply #6 on: May 04, 2015, 06:31:02 PM »
You need to get some made up with "STIG" logo on them, motorcycle racers have tear offs that I'm sure you could get made with that logo.
NeoGenesisMax
« Reply #7 on: May 04, 2015, 07:07:37 PM »
I just look one inch lower
« Reply #8 on: May 05, 2015, 12:31:23 AM »
The other  morning I stopped at two auto parts stores - after fighting the sun.
I could not buy a small piece of the window tint....cheapest piece was $17.
I will try a window tint shop next, for a scrap.
I cannot wear any helmet with a drop-down insert - the edge of that drop-down either hits my glasses - or rests a few mm's away from my nose - like a blade ready to cut me in an off.
My daughter offered me some Snoopy print wall edging she had left over - but it is nearly permanent when glued on.
6 Hondas ago I had a Bell helmet with a 'visor', like my man, Jim Clark. It snapped on. You could do the visor - or snap a  clear bubble face shield on.:
This was before full face helmets came on the scene, top of the line safety equipment.
At sun down you just dipped your head a bit.
manimal
  • 2013 Super 8 150
« Reply #9 on: May 05, 2015, 02:32:34 PM »
I forgot to mention in my initial post, the tint stuff I purchased comes in a roll :p Therefore, you will need to cut a piece, place and trim to fit your visor, as needed. In the end, it will look similar to the painters tape you had initially posted. I'll take a pic and post later. Btw, since installing it, I have not removed it, as it does not hinder my vision, day or night.
« Last Edit: May 05, 2015, 02:39:05 PM by manimal »
~Daren
TroutBum
  • 2012 Like 200i (sold)
« Reply #10 on: May 05, 2015, 03:50:24 PM »
Stig, another source for window tint is at your local hardware store.
Like some here my helmet comes with a flip down visor. When the sun is low enough to come straight on I change direction 90 degrees if I able for a while then change back to my original course.
« Reply #11 on: May 05, 2015, 08:35:58 PM »
I tried that 90 degree trick.
Ended up on Long Island with $3 in my pocket. Missed supper, too.
TroutBum
« Reply #12 on: May 06, 2015, 02:07:56 AM »
like you wanted a short commute home  ::)
GLV55
« Reply #13 on: May 06, 2015, 02:30:42 AM »
Another one here with a flip-down sun visor in my helmet (G-Max GM67). Now that I've had it, I wouldn't own another helmet without one. And I, too, have glasses to work around - took me a long time to find one that works well with my glasses.
2014 Lance PCH 150
2007 Kymco People 150 (totaled by a drunk, Oct. 2013)
Nampa, ID
mnpugdog
« Reply #14 on: May 06, 2015, 03:02:39 AM »
I have also seen at some of the cycle websites they have a precut peice you can buy and put on your helmets
