Hi Winginman,
I have a little more understanding now so I will try to explain a little better.
I had trouble starting in cold and damp conditions overnight. Yes, once the scooter started no problems for the rest of the day. Then the battery died, completely--I had it plugged into a tender which may or may not be faulty. Or the battery may be faulty - don't know.
Dealer found out that the standard computer chip is good for weather above a certain degree, not quite sure what, could be somewhere in the low 30's. I don't think we'd been that low yet, before last night at least.
I had the chip exchanged a week ago for one that handles cooler temps. The recommended setting was 2-3. Still the bike wouldn't start.
Dealer went back to the company and they said sorry for the mistake but the setting should be between 0- and minus 3. Dealer came out and reset the computer but my battery was dead. Had to boost from the kawi, bike started after much cranking.
Punch line: as I understand it--the computer chip business has to do with the richness of the fuel to the injectors. So yes, there was a flooding component to the problem.
Apparently the settings are trial and error. You might ask your dealer what sort of computer chip is in your bike. This is warranty item but I doubt they will volunteer it to you.
