Author Topic: Fuel Filter Leak?  (Read 1007 times)
demeter
Fuel Filter Leak?
« on: May 05, 2015, 04:40:23 AM »
I bought a new fuel filter and had a heck of a time getting those hoses on.. Especially the hose connected to the carb side.
I dried off that little panel under it multiple times and yet everytime after a ride I look and its wet again. Just damp not dripping wet. I don't see a leak or smell gas. My gas has also been going really quick lately. Not sure if thats related or from me upjetting and adding a new exhaust.
The fuel filter is a visu-filter 1/4" with 5/16" barb.
Anyone had the same issue?
2010 Like 50 2T (Malossi 70cc BBK, Tecnigas Next-R, Blue Polini Torque Spring, Yellow Clutch Springs, 5.5g Sliders, Stock Carb: 95 MJ, Stock Airbox Drilled, PIAA GT-X Headlight, Kolite 5630 Running Lights, 140/70-12 Rear Tire)
demeter
Re: Fuel Filter Leak?
« Reply #1 on: May 07, 2015, 09:01:32 AM »
Not a fuel leak but an oil leak. I guess its flowing up the oil tank sensor cables and dripping out at the connector.
The oil tank isn't even half full.. Maybe the hole in the cap is clogged and creating a vacuum.
