Did you miss your
activation email
Exhaust Installed Properly?
Topic: Exhaust Installed Properly? (Read 424 times)
demeter
Jr. Member
May 05, 2015, 10:15:40 AM »
How do I know if I installed my aftermarket exhaust properly? Would I hear a leak? It runs great.
Thanks
2010 Like 50 2T (Malossi 70cc BBK, Tecnigas Next-R, Blue Polini Torque Spring, Yellow Clutch Springs, 5.5g Sliders, Stock Carb: 95 MJ, Stock Airbox Drilled, PIAA GT-X Headlight, Kolite 5630 Running Lights, 140/70-12 Rear Tire)
demeter
Jr. Member
Re: Exhaust Installed Properly?
May 05, 2015, 10:49:59 AM »
Heh.. I'm such an idiot. Duh! Clearly just feel around the gasket for air.
Chris0381
May 05, 2015, 11:08:50 AM »
One of our experienced forum members also mentioned in one thread on some bikes you may be able to stick your finger in the tail end of the exhaust while running and the bike should shut down if everything is sealed.
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
Back
