First thing, if you are running on the oil injector pump; zip tie it wide open. You will need the extra oil to keep everything moving free. I would also add just shy of 1 oz. oil to the fuel. Most certainly run through the rpm range. Give it three-four miles around mid range, and run it up for a few tenths of a mile. varying the rpm's will prevent the new parts from taking a premature seat. I would say two tanks of fuel is PLENTY of break in for a piston/cyl. In moto-x there is NO break- in at all. The most important thing is to use quality 2t oil, and plenty of it. I have been running my injector wired open for a few months now (since i burned a piston) and am planning to keep it that way. I also add about 1 oz. of seafoam to every tank to keep it all clean. You may be a little disappointed w/ the jug kit alone. They don't do too much until you can get the engine to breath right, and start turning some SERIOUS rpm's. Please keep us posted!
