Did you miss your
activation email
Technical | How To
Are special clamps for carburetor connections neccessary?
Topic: Are special clamps for carburetor connections neccessary? (Read 766 times)
MN_Scoot
Full Member
May 05, 2015, 06:01:39 PM »
The intake manifold to carburetor connection and carburetor to air box connection both have clamps like this one from the factory:
http://www.partsforscooters.com/164-297-GY6-Intake-Manifold-Clamp
I have been having trouble finding clamps for a 50cc (plenty are available for the 150cc and I've confirmed those won't fit by trying out.
Can I just use the standard hose clamp like this:
http://www.zoro.com/ideal-hose-clamp-12-to-1-14in-sae-12-ss-pk10-5712/i/G1492276/?utm_source=google_shopping&utm_medium=cpc&utm_campaign=Google_Shopping_Feed&gclid=CKK6m6iXq8UCFQwzaQodTI4A0Q&gclsrc=aw.ds
…or is there a reason top have the specific type of clamp they use from the factory?
Thanks.
2007 Kymco Agility 50
Stock other than Dr. Pulley Sliders and derestricted from the dealer.
Chris0381
Re: Are special clamps for carburetor connections neccessary?
May 05, 2015, 06:18:46 PM »
Dam, you could use a tie wrap.
Should be fine. Tough to pull of the hose even with the clamp off.
Actually you should always carry tie wraps incase one of those cheap chinese fuel clamps fail like one already did on my scooter causing a fuel leak.
Last Edit: May 05, 2015, 06:21:25 PM by Chris0381
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
Carter Merz
May 05, 2015, 06:20:27 PM »
Use zinc plated hose clamps, they never rust. Any old hose clamp will do great though, the factory ones tend to strip out easy.
Reply #3 on:
May 06, 2015, 01:16:48 AM »
zip ties......................
Back
