Author Topic: Little door on ignition  (Read 1033 times)
bucray
  • forever young
« on: May 06, 2015, 08:10:26 PM »
Just spent 45 minutes trying to get the little door that blocks key slot.  Luckily I was next to a Lowes and got big knife and fixed it good.  I've worried about this since I got my GTI300.  What a poor design.
souzamoto
Re: Little door on ignition
« Reply #1 on: May 07, 2015, 04:19:53 AM »
I would say its a good anti thief design if it took you 45 minutes in a Lowes parking lot to disarm it. Lucky someone didn't call the cops
Why didn't you use the key to open the door?
CJS
0BARK4322
« Reply #2 on: May 07, 2015, 08:44:30 AM »
HUMMMMMMMMM.....I LIKE TO HEAR THAT ONE
ALL STOCK
bucray
  • forever young
« Reply #3 on: May 07, 2015, 02:42:26 PM »
the key wouldn't do the job
bluesin
  • 2012 DT 300i
« Reply #4 on: May 07, 2015, 06:18:29 PM »
If you don't have the key with the right side on top, it doesn't work . Did you try turning it over ?
« Reply #5 on: May 07, 2015, 09:10:36 PM »
Our GTi300 and DT300i keys have a "growth" on the side of the key plastic handle that open the little "shutter" or door on the key slot. No brainer. Also in the owners manual.
NeoGenesisMax
« Reply #6 on: May 17, 2015, 04:40:53 AM »
Are you saying you antitheft shutter is broken or the plastic on your key is damaged?
0BARK4322
« Reply #7 on: May 17, 2015, 12:45:20 PM »
Maybe it is not seated properly
ALL STOCK
