Did you miss your
activation email
Scooters - 125 to 300
Bet & Win 150
Drain /empty gas tank
Topic: Drain /empty gas tank (Read 4938 times)
enhkymco150
Newbie
May 07, 2015, 02:26:47 PM »
Hello,
I've been pouring over the maintenance manual and fidgeting with the bike for the last week. How does one drain the fuel tank on the BW 150 without resorting to setting it on fire or throwing the bike into dump?
Thanks,
Ethen
Carter Merz
Re: Drain /empty gas tank
May 07, 2015, 03:26:31 PM »
Take off the RH side skirt, and you'll find the inlet pipe for the fuel pump. You can siphon from this!!
enhkymco150
Newbie
May 07, 2015, 03:45:20 PM »
Ahh! Is that the one connected to the bottom of the fuel pump? Also I found a disconnected port near the top of the gas port (console). Is something missing? Where does it go?
Back
