Author Topic: Help: Xciting 500 (carb) won't start  (Read 12758 times)
guile
« on: May 08, 2015, 11:12:55 AM »
This morning my X wouldn't start. The startermotor turns normally, but the engine won't fire up...
I know there could be many reasons, but where to start?
luckychucky
  • As long as you have your health
Re: Help: Xciting 500 (carb) won't start
« Reply #1 on: May 09, 2015, 02:02:53 AM »
Center stand down, side stand up?
guile
« Reply #2 on: May 09, 2015, 05:05:03 AM »
Got it working again. No idea why it wouldn't start. Hope it will last
guile
« Reply #3 on: May 21, 2015, 08:42:04 AM »
Won't start again!
When starting the sparkplug is quickly flooded so it wont't start en meanwhile the battery runs out of juice. I dried the sparkplug and recharged the battery and after that it would start normally.
This morning wouldn't start again  >:(
When starting the battery icon on the dashboard lights up after 10 seconds. I read on the manual that this means voltage is below 11 volts.
The battery was installed january 2014.
Need ideas guys.
Thanks
xsel777
« Reply #4 on: May 21, 2015, 09:53:41 AM »
I have this issue with my 2010 EFI. I just bought a new battery. Charging measured at battery while idling no lights on, 13.15 volts.  I am told it should be 13.95 . I used to own a grandchild 2006 and the choke was seized solid. Check these mentioned things out.
xsel777
« Reply #5 on: May 21, 2015, 09:54:54 AM »
I am hoping the new battery will keep the morning cold start issues at bay for a while.
xsel777
« Reply #6 on: May 21, 2015, 09:55:24 AM »
I also have trickle charge on during winter here in south Africa.
Scoot parks outside under net gazebo.
« Reply #7 on: May 21, 2015, 03:23:46 PM »
EFI bikes will have lower charging  at idle because it has to run the fuel pump and injectors. Anything over 13v at idle is good. Also the x500 is horrible on batteries, only really get a couple chances to start it before it starts to crank weak.
guile
« Reply #8 on: May 21, 2015, 04:41:54 PM »
Mine has a carb. Guys, is my battery dead?
« Reply #9 on: May 21, 2015, 04:46:14 PM »
does it crank over?
guile
« Reply #10 on: May 21, 2015, 05:16:16 PM »
yes, absolutely
« Reply #11 on: May 21, 2015, 05:43:40 PM »
yes, absolutely
Then the battery is a OK
guile
« Reply #12 on: May 21, 2015, 05:57:39 PM »
Someone explained to me that if there is not enough juice to create a strong spark the sparkplug will flood etc. etc.
Is there a logic in that?
« Reply #13 on: May 21, 2015, 06:56:09 PM »
The 500cc engine is HUGE, so if the battery has enough grunt to crank it over, it has enough to spark just fine. You'll know if the battery is bad on the 500 because it cranks very slow to almost no cranking.
guile
« Reply #14 on: May 21, 2015, 06:59:03 PM »
Okay, but what could be the problem then?
« Last Edit: October 28, 2015, 03:35:21 PM by guile »
