Author Topic: TOP SPEED--AM I CRAZY OR DID A 50CC KYMCO SUPER 9 DO 52MPH  (Read 9446 times)
DEPeople
Re: TOP SPEED--AM I CRAZY OR DID A 50CC KYMCO SUPER 9 DO 52MPH
« Reply #15 on: November 17, 2009, 05:24:57 PM »
I did everything to a chinese 50cc scoot (jonway) and could do 50mph on a flat road....for about 1000 miles, then it started coming apart at the seems. to answer Your question, both. You are crazy, and Your scoot may have done 50+- MPH    ;)
« Reply #16 on: November 17, 2009, 07:54:43 PM »
There you go shaka!!! Just throw more money at it, and it will go faster! Not to rub salt on you, my scoot cost $300.00, and so far I have about 1,600.00 in the GOOD stuff. The next engine alone will be that much plus, 1/2 that again. I would suggest though you get what you have running at it's PEAK, before jumping to the next part. I kinda did the reverse. Worked on the cvt, suspension, then engine. I don' suppose it much matters though. Which ever multi-var you get try to be sure you can match a clutch to it so you will have NO trouble w/ fitting a belt. In my case the kymco stock belt was too big for the malossi multi-var alone, and the malossi was too small to use w/ the stock clutch. I got about 6 mph on the clutch and belt alone.
Shaka
« Reply #17 on: November 17, 2009, 08:10:17 PM »
Thanks Zombie!!  I'm thinking running mine off the end of the pier sounds fun!!
0BARK4322
« Reply #18 on: December 05, 2009, 02:30:13 PM »
YOU GUYS DO SOME GREAT MODS TO YOUR SCOOTS
ALL STOCK
« Reply #19 on: December 05, 2009, 09:30:04 PM »
Thanks! In my case I always have to have something to PLAY with. I am constantly tweaking something to it's limits. Perhaps that has something to do w/ three marriages.
0BARK4322
« Reply #20 on: December 05, 2009, 09:53:10 PM »
WELL I GUESS YOU CAN MOD THE SCOOTERS TO YOUR PERFECT MATE  : 0 )
ALL STOCK
