Author Topic: Is there cruise control// throttle lock a simple way to stay at WOT for 50cc  (Read 5490 times)
KYMCO2TCHLTNC
Is there cruise control or throttle lock a simple way to stay at WOT for 50 cc
I used a hose clamp it worked pretty good >I was just wondering if there was a left handed throttle grip and could  I  hook them togeather and twist both at once.
« Last Edit: June 25, 2016, 05:52:48 PM by KYMCO2TCHLTNC »
wkreps
Check out what I did.
Wayne
Chris0381
I like that.
Any safety issues anyone can think of ?
Lunging into traffic accidentally when meant to be stopped would be my main concern or an accident and the throttle still pumping.
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
wkreps
It's like that with any device. I like this cause it is out of the way and you can just hand twist the throttle back without having to unhook or move any levers.
Wayne
0BARK4322
THIS IS WHAT I USE
ALL STOCK
Chris0381
Would these work. Just clamp it down real tight and zoom off.
Smooth Boss
Polini Variator
#95 Main Jet
AMAC1680
    • SEGS4VETS
I used that method on the Harley for 25 years, works great.
Saftey issues someone asked ? Well you're wedging a rubber o-ring between the throttle and the barend lots of bad doo doo can happen. The worst is the gas stays open and you crash going real fast. ;)
For me still worth the risk.
Be Big,
AMAC
www.SEGS4VETS.org
2017 Lance Cali Classic 200i
2013 SYM RV200
2013 Kymco Downtown 300
2010 Lance Cali Classic-sold
1973 VW Dune Buggy
1974 VW Meyers Manx
0BARK4322
Just use the go-cruise, I've used it for years 8)
ALL STOCK
2wheelfun
You guys need stronger wrists, maybe a pic of Jessica Alba nude might help ya out.
AMAC1680
    • SEGS4VETS
Hehehe now that's funny.
Be Big,
AMAC
www.SEGS4VETS.org
2013 SYM RV200
1973 VW Dune Buggy
1974 VW Meyers Manx
my mind always go,s to 1940  Jane  Russel
demeter
lol  ;D
2010 Like 50 2T (Malossi 70cc BBK, Tecnigas Next-R, Blue Polini Torque Spring, Yellow Clutch Springs, 5.5g Sliders, Stock Carb: 95 MJ, Stock Airbox Drilled, PIAA GT-X Headlight, Kolite 5630 Running Lights, 140/70-12 Rear Tire)
08087
  • 09' Peoples 200, NJ
I have to ask, what's so hard about keeping your hand in the full twist position?
0BARK4322
I'm guessing he want to use it for repairs or something
ALL STOCK
wkreps
No problem unless I'm going long distance. Then the full tension of holding the spring starts to get to my muscles. Much like it's no problem holding a full can of soda straight out from your body but try doing for an hour solid. Muscles start to get fatigued.
Wayne
