Your in luck, Kymco provided the two stroke bikes with an adjustable oil meter!!! If you take the seat out, you will see where the throttle cable pulls the oil pump, and just turn the lock nuts so it opens the oil pump a little more. No reason at all to add any in the gas. What pipe did you get? Did you up jet for it?
