Author Topic: 2010 xciting 250i "eating" oil  (Read 1760 times)
leo.portner
« on: May 11, 2015, 05:29:06 PM »
Losing 100-200 grams/ml of engine oil every month,
No visual leaks every thing is dry and clean.
Any thoughts where the oil is going?
Re: 2010 xciting 250i "eating" oil
« Reply #1 on: May 11, 2015, 06:02:38 PM »
No spots on the floor or gooey spots on the bike then it is either past the rings or valve guides and out the tail pipe/muffler.
leo.portner
« Reply #2 on: May 11, 2015, 06:16:36 PM »
No oil on the floor no spots on the bike.
Bike dosnt smoke at all, but you might be right
« Reply #3 on: May 11, 2015, 07:35:39 PM »
Yeah, that amount probably would not show smoke.
« Reply #4 on: May 11, 2015, 09:23:48 PM »
How many miles or km do you put in that month?
leo.portner
« Reply #5 on: May 12, 2015, 09:31:31 AM »
600-800 km
« Reply #6 on: May 13, 2015, 04:28:50 PM »
That's fairly normal oil usage. These motors aren't like car engines, the tolerances are much much larger and can let oil past the rings etc. No matter what the manual says, the 250 motor likes the oil changed about every 1000km I've found with mine. On my next rebuild later this month, I'm thinking about just using fairly cheap oil instead of Motul, frikin' $16 every 1000km gets expensive LOL.
leo.portner
« Reply #7 on: May 13, 2015, 07:56:59 PM »
Yep
