Author Topic: TOP SPEED ON THE PEOPLE 200s  (Read 9494 times)
0BARK4322
« on: May 13, 2015, 11:34:58 PM »
I TOOK OUT MY GPS TO CHECKED THE TOP SPEED  AND THE TOP SPEED WAS 61MPH MPH AT THROTTLE LOCKED AND A 1 MILE RUN.....OUTSIDE TEMP WAS 62 DEGREE'S FLAT ROAD......
ALL STOCK
Re: TOP SPEED ON THE PEOPLE 200s
« Reply #1 on: May 13, 2015, 11:44:55 PM »
Sounds about right for an all stock s200. If you are open to it, I have a few ways to drastically improve the top speed. http://www.drowsports.com/taida-gy6-camshaft-t100/
Dr. Pulley variator and sliders. These things and a good solid tune (Valves good, new spark plug, good oil, tire pressure good) Should get you close to 70mph GPS. My Girlfriends S200 has a custom exhaust, a12 cam, 30mm carb, and sliders and hits 80mph indicated all day long.
0BARK4322
« Reply #2 on: May 13, 2015, 11:50:16 PM »
Is there an easier way without taking the engine apart
ALL STOCK
« Reply #3 on: May 14, 2015, 12:14:01 AM »
Little work = little gains. The fist step would be to order the Dr. Pulley Variator with some 11-12g sliders
http://www.amazon.com/Dr-Pulley-GY6-Variator-Kit/dp/B007PV9E1I
the sliders are 18mmX14mm and I've had good luck around 11-12g with a mostly stock engine. Check that your tire pressure are around 30psi fr and 35psi rear, higher than in the owners manual but you will see slightly better top speed with this. The camshaft is fairly easy to install, most shops should only charge about an hour labor to put it in and you will see HUGE gains with this.
0BARK4322
« Reply #4 on: May 14, 2015, 12:19:46 AM »
Hummmm, maybe worth looking too. I think i need to increase my miles on the scoot.....not a 1000 miles as yet
ALL STOCK
« Reply #5 on: May 14, 2015, 02:31:49 AM »
Did it have it's first valve check performed? I would do that right away if its got around 1000mi. Great scoot man, I love the S200 and it's a shame they stopped importing such a good machine. One thing to consider in the next couple 1000mi, the stock tires SUCK on the s200, they have a very strange "s" tread pattern that ALWAYS wears funny and causes the bike to feel bad. Consider finding a tire you like and swapping even before those stock tires are worn, it'll feel much better.
0BARK4322
« Reply #6 on: May 14, 2015, 08:28:11 AM »
All the service was don't last week on the scoot and the tires are kenda(something like that) but i'm sure they are a cheap brand. It does ride nice and i am enjoying myself on some nice rides. I wouldn't mind having at least a 5 mph increase in speed
ALL STOCK
AMAC1680
    • SEGS4VETS
« Reply #7 on: May 14, 2015, 10:33:42 AM »
I hate to say this but if you wanted 65 you bought the wrong scooter. The top speed of the s200 is well documented here and you are on the high end right now. Tires and a tunes not gonna get you 65.
By the time you spend the money to get the speed you want you should have bought a bigger scoot.
That's if you really need the extra MPH.
Be Big,
AMAC
www.SEGS4VETS.org
2017 Lance Cali Classic 200i
2013 SYM RV200
2013 Kymco Downtown 300
2010 Lance Cali Classic-sold
1973 VW Dune Buggy
1974 VW Meyers Manx
« Reply #8 on: May 14, 2015, 10:16:37 PM »
Be Big,
AMAC
+1
(how many times have we read of a new scooter owner looking for "more  speed" ?)
0BARK4322
« Reply #9 on: May 14, 2015, 11:53:17 PM »
I only stated 5 mph more that's all. I have read plenty of time that the top speed was around 55 to 60 mph but hey, even you want a little out of you scooter or motocycle just for the heck of it. I've seen guys with 1400cc bikes and still want more. The style of the people 200 is to my liking so i am pleased with it and plan on having for a long time just like my super 9 (12 years and counting) 8)
ALL STOCK
AMAC1680
    • SEGS4VETS
« Reply #10 on: May 15, 2015, 02:32:24 AM »
Hey you should love that scooter. I had one and it gave me flawless service. I think you'll find it fast enough 99 percent of the time.
Enjoy it and all the best with it.
Be Big,
AMAC
www.SEGS4VETS.org
2013 SYM RV200
1973 VW Dune Buggy
1974 VW Meyers Manx
0BARK4322
« Reply #11 on: May 15, 2015, 08:27:47 AM »
Be Big,
AMAC
Thanks man, I've had nothing but good luck with my super 9 so i should have a blast with this one being i use it daily for my commute ;D
ALL STOCK
SUPER 9 MANN
« Reply #12 on: May 15, 2015, 11:43:48 PM »
that is the best way to get your moneys worth
« Reply #13 on: May 15, 2015, 11:56:57 PM »
My friend put 40k KM on doing delivery, then sold it to my cousin and its still going strong. The s200 lasts forever if you take good care of the engine!!!
SUPER 9 MANN
« Reply #14 on: May 16, 2015, 01:07:56 PM »
i am hoping to get one. i like the body style of those scooters
