Author Topic: eBay variator and roller weight kit????  (Read 1079 times)
FBR090375
« on: May 15, 2015, 06:18:03 PM »
What are the pros upgrading my agility 125,with a performance variator and roller weights,I have seen kits  on eBay from 30 to 130 DLLs,what brand of rollers do you recommend,also what weight of rollers,I am a big guy 300 pounds,is this avoid investment or waste of money
Re: eBay variator and roller weight kit????
« Reply #1 on: May 15, 2015, 06:46:03 PM »
I would not buy a cheap-o kit because the OEM kymco variator is higher quality than most cheap china kits. If you want to buy a variator get either Dr. Pulley, or Malossi. And stick with Dr. Pulley sliders for weights, the cheap ones are CRAP.
SUPER 9 MANN
« Reply #2 on: May 15, 2015, 11:47:19 PM »
sometimes you spend more you get more
« Reply #3 on: May 15, 2015, 11:55:56 PM »
This saying is more true than not with performance parts......
FBR090375
« Reply #4 on: May 16, 2015, 11:34:17 AM »
Where can I find a good kit malossi,or just by the Dr pulley rollers,please help me,any us scooter parts store,should I buy rollerpoligon sliders 12 grams. Or 10gm and use the original kymco variator,
