Author Topic: Gas tank  (Read 1023 times)
mattyjay
Gas tank
« on: May 15, 2015, 08:20:16 PM »
Hi all
Today I found out the hard way my fuel gauge/sensor has broken.
How do I fix this, really desperate for some help!
Thanks
Re: Gas tank
« Reply #1 on: May 15, 2015, 09:05:04 PM »
Do you have a known good battery? A dead battery will throw off the gas gauge.
mattyjay
Re: Gas tank
« Reply #2 on: May 15, 2015, 10:08:32 PM »
That's a good shout, I better give that a charge first. If it's not, what else would you suggest?
Re: Gas tank
« Reply #3 on: May 15, 2015, 11:59:33 PM »
If the scooter sat around unused for a while, the sensor could just be stuck. You can remove it and use PB blaster to lube it, or go fishing for the float with a bent clothes hanger. Sometimes just shaking the scooter or going over a rough bump helps.
mattyjay
Re: Gas tank
« Reply #4 on: May 17, 2015, 10:44:50 PM »
Now I feel silly, had a good look with a torch, and saw the sensor floating freely  ::)
Well I've ordered a new one and will fit that when it arrives!
