Did you miss your
activation email
Super 8 150cc front brake wobble
Poll
At 1500 miles I seem to have developed a serious front brake tire wobble
Front brakes
0 (0%)
Covered under warranty?
0 (0%)
Total Members Voted:
0
Topic: Super 8 150cc front brake wobble (Read 787 times)
andrito
Newbie
November 17, 2009, 08:38:05 AM »
The riotor looks and feels fine, but when you press on the front brakes moderate to hard, it makes the whole front end shake and wobble. Any ideas what I should check to correct this problem? Could this be a warranty issue?
You never know do ya!
Close enough to get the idea!
Re: Super 8 150cc front brake wobble
November 17, 2009, 02:42:52 PM »
Sounds as if the rotor is warped or loose. B:the caliper is loose. C: the front axle is loose. D: the triple tree is loose. E: bad wheel bearing. F: loose shock. Can you see any deflection in the rotor if you spin it quickly by hand? There are many possible causes. I would certainly have a dealer look at it if you cannot find the cause yourself.
Back
