Author Topic: Exh manifold broke, AGAIN!!!  (Read 1680 times)
leo.portner
« on: May 20, 2015, 07:37:44 PM »
Was doing 80mph on the freeway when a loud bang and then brrrrrrrrraaaaaapppp
Already know that sound so i stop at the side of the road pick up the broken peace that is dragging on the road and keep going until i make it home...
Had to get a new manifold from the wreck yard
Re: Exh manifold broke, AGAIN!!!
« Reply #1 on: May 20, 2015, 08:49:35 PM »
Double check the torque on the three hanger bolts, if these are loose you will keep breaking exhausts. Warm the bike up and check the tightness, use blue loctite.
leo.portner
« Reply #2 on: May 22, 2015, 06:10:56 PM »
Wtf is a tree hanger??
« Reply #3 on: May 22, 2015, 06:26:56 PM »
No, THREE LOL. The bolts that hold the muffler to the swingarm are called "hanger bolts" make sure they are torqued to spec because if they are loose you will keep breaking manifolds.
leo.portner
« Reply #4 on: May 22, 2015, 06:52:10 PM »
LOL
any chance you have the torque specs
« Reply #5 on: May 22, 2015, 06:54:57 PM »
LOL
My torque spec: Impact gun set on high for a couple bursts :) With blue loctite
leo.portner
« Reply #6 on: May 22, 2015, 07:00:20 PM »
Ok so i will check the tree hanger bolts
