Author Topic: 2014 uxv 700i will not start  (Read 4851 times)
laidback
« on: May 21, 2015, 03:15:19 AM »
Uxv 700I not starting it cranks but no start I checked for spark it's got it I checked fuel pressure it's good so I pulled the injector and it sprays a small mist but I don't think it's enough. Anyone elese had that problem? It's at the dealer now when they find the problem I'll post it. It's nice to have a one year warranty not six months like the other brands. :D
« Last Edit: May 25, 2015, 03:44:22 PM by laidback »
JoeMarshall
Re: 2014 uxv 700i will not start
« Reply #1 on: June 01, 2015, 12:58:05 AM »
Did you ever figure out what the issue was. Mine did this to me once in the winter while I was plowing. It just died an didn't want to start. But after 10 minutes or so it fired and ran fine.
laidback
« Reply #2 on: June 01, 2015, 03:55:28 AM »
I took it to the dealer they told me it had water in the fuel and they were gonna charge me $245.00 to clean it out. If it had water in the fuel it would run like 💩 I told them there is no way it has water in the fuel I've never had water above the floor and I use the same gas in our other atv's and don't have a problem. I told them it's got to be a problem with the injector or the control module. So they called me back the next day and told me they have determined that it is the injector.
laidback
« Reply #3 on: June 17, 2015, 03:45:31 PM »
I picked up my kymco from the dealer yesterday and the problem was not the fuel injector it was the electronic control unit. So if anyone has the same problem it may be that. :)
JoeMarshall
« Reply #4 on: June 21, 2015, 02:57:22 PM »
Thanks for the info. It's great when people put it on the posts when they have issues and what resolved them.
laidback
« Reply #5 on: June 28, 2015, 07:36:58 PM »
Since I've gotten my buggy back from the dealer and they replaced the ecu I have a new top speed and I haven't hit the rev limit. Before it would top out at 45 mph 7000 rpm and hit the rev limit. Now it's 48 mph still at 7000 rpm but dosent cut out from the limiter.
