Author Topic: To manual choke or not to manual choke, that is the question  (Read 6412 times)
Scootsuper9
Re: To manual choke or not to manual choke, that is the question
« Reply #30 on: May 28, 2015, 12:33:37 PM »
Sell your super 9?!?!? :o
TheAmishSasquatch
« Reply #31 on: May 28, 2015, 04:38:54 PM »
Possibly trade. I have a hard one for 2nd gen Aprilia SR50's. The S9 was my 2nd choice. Ill probably just havel both :p
Scootsuper9
« Reply #32 on: May 28, 2015, 06:03:10 PM »
Ya aprillas are nice. But if you can find one, for a good price that's in good condition lucky you! I had a hard enough time getting my super 9.
TheAmishSasquatch
« Reply #33 on: May 29, 2015, 08:56:03 PM »
Well, today I finally did it. I just ordered a 19mm black edition Dellorto PHBG. I figure it should be here in a month orPHBG. Ill update once it arrives. Thanks for the help everyone.
« Reply #34 on: May 29, 2015, 09:24:32 PM »
Let me know if you need any help setting it up.
Scootsuper9
« Reply #35 on: May 29, 2015, 10:09:17 PM »
congratz  ;)
TheAmishSasquatch
« Reply #36 on: May 29, 2015, 10:49:24 PM »
I just messaged zombie, but Im sort of in a hurry. Whays the best plug to run? I already have a ngk bpre8 <?  Timing is advanced slightly, going to use aftermarket CDI, larger carb and probably a velocity stack on the carb. Thanks
TheAmishSasquatch
« Reply #37 on: May 30, 2015, 03:16:50 AM »
Sorry for my impatience earlier, group. I was out and about and was hoping to get the spark plug today because rain is in the forcast for tomorrow and I don't take the bike out in the rain. Still would like to here opinions on plugs please. Thanks
« Reply #38 on: May 30, 2015, 06:23:22 AM »
Br8hsa if it's ac
TheAmishSasquatch
« Reply #39 on: May 30, 2015, 12:40:24 PM »
Thanks Betting.  Is that the standard NGK upgradNGor is that one of the other options? I currently have an NGK in the bike (unsure which). Whats you take on iridium?
Scootsuper9
« Reply #40 on: May 30, 2015, 01:41:01 PM »
Get the standard ngk plug imo works best. Using an iridium or multi conductor plug or what have u is a waste of $.
« Reply #41 on: May 30, 2015, 03:21:36 PM »
Agreed, especially in a2t where they use up plugs fast anyway. The only advantage of iridium is it lasts longer, regular copper core actually is a better conductor.
TheAmishSasquatch
« Reply #42 on: May 30, 2015, 04:32:49 PM »
Thanks fellas. My plug is only about 4 months old (I know that's irrelevant as a plug can foul in under 5 mins) just seems like I should be getting better ignition and economy. Any of you familiar with the Ford coil upgrade? I'm considering doing it.
Triesandluth
« Reply #43 on: May 30, 2015, 07:53:09 PM »
My LC had bpr7hsa in it when I got I it,  went to an 8, then tried a 9 after my kit.  I fouled out the Nine,  went back with the eight and have been on it since.
I used an iridium for a good while.  I had my self thinking it provided a solid and better starting.
Triesandluth
« Reply #44 on: May 31, 2015, 10:33:58 PM »
Ya. I didn't mess with the airbox but this is what that person did
Look what I did! Modded the airbox!  $2.99 a foot at Lowe's.  Very simple.  Since it fit well I'm going to open up the hole for the snorkel intake and use the same tubing to run up under the body.  Bonus,  it matches the paint scheme perfectly!
