Author Topic: New tool in my equipment bag.  (Read 831 times)
Chris0381
« on: May 26, 2015, 10:20:55 AM »
After being extremely busy for 6 days and no scooter riding, I decided to take a ride and the scooter just wouldn't start.
I tried spraying some carb cleaner into the carb to get some ignition but the can was empty.
After 5 mins of no start, I decided to get an eyedropper and take a small amount from the tank and squirt it into the carb and the scooter started right up.
So from now on, a small plastic eyedropper will be part of my scooter tool kit carried with me at all times.
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
0BARK4322
Re: New tool in my equipment bag.
« Reply #1 on: May 26, 2015, 11:58:40 PM »
Is it starting up normally now without the eyedropy tooly thingy
ALL STOCK
« Reply #2 on: May 27, 2015, 12:42:14 AM »
LIKE200i owners must purchase a Canadian butter knife in order to safely do a valve check.
Please see the utube of the LIKE200i valves job.
https://www.youtube.com/watch?feature=player_detailpage&v=eipDXgGdh6o#t=154
There are all kinds of tricks involved in scooter ownership!
mrbios
  • 2005 Kymco Grandvista 250cc
    • My YouTube Channel
« Reply #3 on: May 27, 2015, 06:03:33 AM »
When things are setup and maintained correctly you should never need it.  My scoot starts instantly even if it sits in the rain for weeks.  I used to keep starting fluid around for old lawn mowers in the winter or even my dad's old Sthil 041 "Farm Boss" chainsaw.  20 years of use and sucking in lots of junk it didn't like to start.  Last time I ran it was 2008 took 25+ pulls with starting fluid to get it running.  Other vehicles - 1941 international brand dump truck - cracked piston rings - would prime it with a cup of gas down the carb but that was because the motor had so little compression.
Carburetors have an accelerator pump so when you twist the throttle it makes the carb squirt gas.  You might want to do a good tune up.  Should need to resort to that.
PaulC
