Author Topic: low beam/high beam and panel lights not working-passing is ok?  (Read 946 times)
brainpann
Hi and thanks in advance.  I have a 2003 Kymco People 50cc and last week the low beam, panel light, and the little bulb inside the lamp assembly quit working. Only the passing light works. However, my signal and break lights work fine.
I have since replaced all the lights with a new bulbs, checked the fuses, and even tried cleaning the switch but nothing seems to work. Id appreciate it if someone with a lot more knowledge could point me in the right direction on how to fix this.
Thanks again.
« Last Edit: May 26, 2015, 08:21:16 PM by brainpann »
Re: low beam/high beam and panel lights not working-passing is ok?
« Reply #1 on: May 26, 2015, 08:52:52 PM »
You know about the headlight switch on the right handlebar correct? Theres a switch below the kill switch to turn the lights, on, off and running.
brainpann
« Reply #2 on: May 26, 2015, 09:10:53 PM »
DOH! I feel like such a doofus. I thought it would only switch between high and low and must have hit it by mistake.
Thanks- I was starting to get pretty annoyed and thought that Id have to examine the wiring.
« Reply #3 on: May 26, 2015, 09:37:34 PM »
No worries, this happens all the time at our shop. Cheers!!! and now you have new bulbs!!! haha
