Author Topic: axle nut  (Read 1060 times)
sjb9989
axle nut
« on: May 29, 2015, 12:46:26 AM »
Does any one know the axle nut size, for removal. Thought it was a 24mm socket...but it was wrong size.
Had a flat tire...closest dealer 20-25miles away.
Never look back, because someone my pass you.
          Proud owner 2009 Xciting 500r
sissy mary
Re: axle nut
« Reply #1 on: May 30, 2015, 07:59:19 PM »
It's 27 MM. Buy a product called (Ride On). it's a tire sealer and balancer. Much better than slime, will not dry out, and much smoother out on the open road. I have never had a flat with it! :-*  P.S. This is the same size socket as the large nut on the variator. I would buy an impact version, buy a cheap electric impact wrench from harbor frieght or else where, and change your own belts, rollers etc.  :-* Good luck. ;D :-*
