Did you miss your
activation email
Scooters - 125 to 300
Downtown 300
Max speed went from 82 to 90mph!
Topic: Max speed went from 82 to 90mph! (Read 1204 times)
spikebites
Newbie
May 29, 2015, 06:35:26 AM »
When I first got my Kymco DT 300 a year ago, my max speed at full WOT was 82mph.
Today, after 2500 miles, I noticed my max speed at WOT was 90mph @ 8000rpm.
How awesome is that? Just curious, will it go any higher than that?
2011 300i downtown 82,265 KM.
Re: Max speed went from 82 to 90mph!
May 29, 2015, 12:22:29 PM »
It is just broken in, you will see about 95 MPH. tops,. unless you do some mods,. some people in germany had there scooters over 100 MPH.
Carter Merz
May 29, 2015, 03:26:39 PM »
Also wind, how many cheeseburgers you ate that day, tire pressure, oil level,temperature and humidity, all these and more play into top speed.
RubenC
Full Member
Reply #3 on:
May 30, 2015, 08:54:41 PM »
Hi
I have did 95 once but then I still had some throttle before it was WOT. I was fun and scary at the same time.
From the Great Nation called Texas. Oops I mean the Great State called Texas
Back
