Author Topic: People 50 dying after start  (Read 1074 times)
NoahB
« on: November 22, 2009, 01:47:27 AM »
I'm having some issues with my People 50. Apparently it spent the last 2 years in a garage with bad gas in it. I have drained the gas, filled it with a new tank, added some seafoam, charged the battery, and it finally starts. The problem I have now is that while it is idling, if I give it any gas it bogs down and dies. The kick start works 99% of the time, the electric start will work if I use it after it has been running from a kick start. As I start it and it dies time after time the idle gets rougher and it will only run for about 10 seconds after the 6th or 7th go around.
I have an apartment so I don't have an area to do any serious work on it. Any ideas that don't require taking the bike apart?
Re: People 50 dying after start
« Reply #1 on: November 22, 2009, 04:08:23 AM »
Remove the carb , and  clean the jets. Brake clean will help quite a bit. A sewing needle will also help
jprestonian
    • a scooter called wanda
« Reply #2 on: November 22, 2009, 04:37:51 AM »
Agreed. The carb is probably pretty gunked up. Also, check that all your air intake connections are tight, and no cracks. Your battery may be weak or on its way out, too.
